Green Basics
Space Heaters
A Space Heater Can Be the Sole Source of Heat in a Small, Well-Insulated House
ABOUT SPACE HEATERS
Heat without a whole-house distribution system
Space heaters are usually categorized by the type of fuel they burn. Options include cordwood, wood pellets, and corn (all forms of biomass), natural gas, kerosene, and electricity.
Because space heaters have no way of carrying heat to distant rooms, they work best in houses with open floor plans and those that allow convective air currents to circulate heat. However, the more airtight and well insulated the house, the less distribution matters. Very tight homes with thick insulation are more likely to have uniform temperatures from room to room than leaky houses.
In rooms that are used only occasionally, it may be more economical to install a space heater and use it only when needed rather than keeping the room warm all the time with a central system.
  • Green Basics
    Water Heating
    UPDATED 04/05/2012Tank or Tankless: Reduce the Load to Lower Water Heating Costs
  • Green Basics
    Boilers
    A New Generation of Boilers Is Super Efficient
  • Green Basics
    Heat Pumps: The Basics
    Heat Pumps Use Heat in the Air, Earth, or Water to Heat a House
  • Green Basics
    Green Heating Options
    Green Heating Systems Can Heat the House and Its Water
