Article
The Mold Explosion: Why Now?
Mold comes from moisture problems. So where do moisture problems come from?
Today’s houses seem highly susceptible to mold. Building scientist Joseph Lstiburek explains why: wood products that can’t tolerate mold; houses that don’t dry out properly; hollow walls stuffed with insulation; and how the way residents use the mechanical systems affects the house’s envelope. Lstiburek says that the fix to mold problems is clear: Water problems must be repaired quickly to prevent water from entering today’s high-performances houses. The article includes sidebars on whether moldy framing lumber can cause rot, how mold can make residents sick and how to remediate a mold problem.
The Mold Explosion Why Now_FHB184.pdf
