Video: Installing Rigid Foam Under Footings
This construction site video of the Karuna House in Yamhill County, Oregon, demonstrates installation of a geofoam foundation that will superinsulate the bottom of the building envelope and help the project achieve Passive House and Minergie-P-ECO certifications.
Lead Carpenter Scott Gunter narrates the process of:
  • screeding out gravel,
  • back dragging with rake as needed,
  • compacting gravel,
  • marking outside foundation wall line on foam,
  • setting and aligning geofoam, and
  • drilling and pinning geofoam into place.
The Karuna House is designed by Holst Architecture and built by Hammer & Hand.
For more information on this topic, see Foam Under Footings.
Installing rigid foam under a footing in Yamhill County, Oregon
Karuna Passive House – geofoam foundation installation with Hammer & Hand’s Scott Gunter from HammerAndHand on Vimeo.
4 Comments
  1. jklingel | | #1
    What psi foam is used? It
    What psi foam is used? It would be nice to see how they build the footer forms, etc, as well.
  2. Skylar Swinford | | #2
    Foam PSI
    John,
    Thank you for checking out the video. Under the footings we are using 2.40-2.50 lb/ft3 EPS39 (Geofoam title) or Type XIV (EPS title). Under the slab we are utilizing 1.35 -1.50 lb/ft3 EPS22 or Type II.
    More info can be found on the project website: http://hammerandhand.com/_blog/Field_Notes/post/Passive_House_construction_time-lapse_a_mountain_of_foam,_delivered/
    Hopefully by next week we will have a video of the next steps in the process. Our intent is to document the project each step of the way.
  3. user-1006269 | | #3
    Critters
    Is my concern of ants, termites or critters living in this amount of insulation founded?
    We have done foam panel foundations, but wrapped the foam in 65mil EPDM. I was still a littler nervous about something getting in.
    I wonder if building an uninsulated foundation system is more prudent and then superinsulating inside the basement or on top of a slab and decking over that. I don't know but wonder if it makes sense.
  4. kevin_in_denver | | #4
    Two Big Reasons for "Outsulation"
    Tom,
    Insulating the outside provides at least two hidden cost savings, in addition to adding beneficial thermal mass:
    1. The concrete can be stained and polished for a durable, almost free floor surface.
    2. Insulating the outside and applying Frost-Protected-Shallow-Foundation principles, the thickened edge slab can be only 16" deep throughout the US.
