green-building-newsheader image
0 Helpful?
A New Guide for Net Zero Builders
California architects' group publishes a primer on net-zero energy building
Posted on May 15 2018 by Scott Gibson
California's steady move toward net-zero energyProducing as much energy on an annual basis as one consumes on site, usually with renewable energy sources such as photovoltaics or small-scale wind turbines. construction has prompted the publication of a new guide for architects called the Zero Net Energy Primer.
Written by Ann V. Edminster, an architect (and a member of the GBAGreenBuildingAdvisor.com advisory team), the ZNE Primer was published by the American Institute of Architects, California Council and financed by Pacific Gas & Electric. It comes against a backdrop of increasingly stringent requirements in Title 24, the state's efficiency code for buildings.
California has the largest concentration of net-zero homes in the country. A 2017 report from the Net ZeroProducing as much energy on an annual basis as one consumes on site, usually with renewable energy sources such as photovoltaics or small-scale wind turbines. Calculating net-zero energy can be difficult, particularly in grid-tied renewable energy systems, because of transmission losses in power lines and other considerations. Energy Coalition said that 5,279 of the 13,906 net-zero residential units in North America are located in California. More will be on the way in the wake of a vote by the California Energy Commission earlier this month to require single-family to include solar panels beginning in 2020.
"Significantly, more than 90% of these homes are in developer-initiated, multi-unit projects, demonstrating that these pioneering developers believe that ZNE makes solid business sense — and not just at the high end of the market," Edminster's introduction reads. "The inventory includes thousands of units of ZNE workforce housing and production homes, in a wide range of US climates. The takeaway is that ZNE is highly affordable when you know how to do it."
Net-zero for electricity use
Exactly what "net zero" means often depends on who you ask. Loosely speaking, a net-zero energy house is one that produces as much energy as it uses over the course of a year through a combination of energy-efficient building design and on-site energy production. But definitions can include both "site" and "source" energy and require designers to calculate energy equivalencies between various types of fuel and where the energy was generated.
In this case, the 2019 version of Title 24 requires builders to include a large enough PVPhotovoltaics. Generation of electricity directly from sunlight. A photovoltaic (PV) cell has no moving parts; electrons are energized by sunlight and result in current flow. array to offset typical electrical loads, Edminster said in a telephone call. Mixed-fuel houses — houses that burn natural gas as well as use electricity — won't have to include solar panels that generate the equivalent of gas-produced energy. But the next version of Title 24 may be different, and by 2030 the state could be imposing net-zero standards on commercial buildings as well.
California will require that architects submit their designs, along with a Title 24 report, showing how the building complies with the code. But it doesn't require any documentation on actual energy use after occupants have moved in. Compliance grows more complicated with the addition of "time-dependent valuation" that's designed to set the relative value of energy based on when it is produced and when it's used.
Although challenging in some of the details, Edminster calls the code changes "ZNE light, or ZNE-ish," far from the intent of Gov. Arnold Schwarzenegger's original and sweeping net-zero pronouncement back in 2006.
Building details for everyone
Edminster said the guide is aimed not just at California architects, but the entire building community, and should be relevant well beyond the state's borders.
"In simplest terms, ZNE is nothing more than a very efficient building with photovoltaics on top," Edminster writes. The guide outlines how architects can address the three keys to meeting net-zero requirements: building an efficient thermal enclosure, choosing highly efficient mechanical systems, and installing solar energy systems.
Complaints from architects about the new energy standards and solar requirements have been muted.
"Anybody who's been paying any attention knows this has been coming for quite a long time," she said. "We've had a dozen years since the original pronouncement and the implementation, which still falls fairly significantly short of that aspiration. So I don't think anybody's really startled."
Even the building industry's trade groups, which normally might be digging in their heels at new requirements, have found the new codes "pretty reasonable," she said.
One exception: architects who cater to the wealthy. It will be harder and harder for them to get away with floor-to-ceiling glass in the houses they design, Edminster said, because plans can't swap more PV for lower building efficiency.
"There will be some resistance," she said. "But they will cope."
This post was UPDATED on May 15 to include more recent data from the Net Zero Energy Coalition.
Tags: , , , ,
1.
May 15, 2018 6:52 AM ET
I applaud their efforts and
by Calum Wilde
I applaud their efforts and their stance on these issues. ""There will be some resistance," she said. "But they will cope."" No pandering or back pedaling, just a 'get it done' attitude. If I was going to move to the US this is the one place I find attractive. Well, northern Californian. Southern would be way too hot.
2.
May 15, 2018 11:21 AM ET
Thank you Ann and company
by Armando Cobo
As an exclusive ZER homes Designer, I find this Primer a great resource to help educate Builders, trades and homeowners on the basics of designing and building these homes. Thanks for sharing it too.
Everyone in the industry needs to understand that a successful ZER project starts with a commitment, follow by the design, detailing and documentation, follow then by educating the builder and trades, and finally supervision and commissioning. Any weak link in the process could bring a risk of failure.
3.
May 15, 2018 1:30 PM ET
Edited May 15, 2018 1:31 PM ET.
Armando,Have you tracked the
by Calum Wilde
Armando,
Have you tracked the net usage of any of your builds after construction? Any input on the assumptions that are often made about homeowner's usage and the reasons it varies so much?
4.
May 15, 2018 7:18 PM ET
Tracking results
by Armando Cobo
Yes, we have and do. About 3/4 of my clients do not install the PV system because their energy bills are very low, and they don't see the ROI investing in a system at the current prices. The 1/4 of clients who install PV systems at 2kW/hr pr sq. ft., they get between between 65%-90% of their electric needs. We don't have true net metering in TX, but we do in the South West, where the percentage is better.
I must say that most of my designs are +5,000 sq. ft houses, with large swimming pools, saunas, theaters, wine cellars, etc., plus every imaginable "need". Almost every time we achieve HERS 40-42 w/o PV, 1ACH50, and we typically install 1 ton per 1,200-1,500 sq.ft., ES lighting, plumbing and appliances.
5.
May 16, 2018 12:38 AM ET
Metric Units
by Mike Clarke
A very useful initial document.
Is it possible for the author to be able to provide metric units (in brackets) - only in the US do they refer to heating capacity in tons.
I appreciate that it's not to difficult to do the conversions, but it would make the document more easily read, for us folk outside of the US.
6.
May 16, 2018 3:58 PM ET
The target audience is California, not even US @ Mike Clarke
by Dana Dorsett
The document is addressing issue specific to compliance with California Title 24 efficiency code requirements. To include metric measures even in brackets would not be appropriate, since Title 24 does not use metric units for anything except electrical power.
Everything else in the code (thermal loads & outputs, weights & volumes, temperatures, R values, U-factors, etc) specified in CA Title 24 use non-metric units, or sometimes hybrids thereof. eg: Th HSPF heat pump efficiency is a hybrid, the seasonal average efficiency expressed in units of BTUs per watt-hour rather than a unit-less coefficient of performance (COP.) This is done because space heating loads and combustion heating appliances capacities in the California (and the rest of the US) are expressed in BTUs per hour, not watts, as is done elsewhere.
Become a GBA PRO!
